ok i am building my front dana 60 and i only want to build it once and not break it that often un like my current set up(dana 44) which gets broken every time i go out i have been reading just about every thing i can search for on 40 spline stubs for the d60 because i am looking to control colateral damage aka make the part that is going to break and not take any thing else out with it so i will be leaving the inner axles 35 spline cause when they go boom it will not mess anything else up
and adding up the cost it looks like it will cost about 2k to run the 40 spline stubs over running the 35 spline stuff
so i guess my question is what is the streangth differance between a 40 spline shaft and a 35 spline shaft and is it worth 2k
specs of the rig
sbc 327 with about 300hp for now, sm465, dana 300 with 4 to 1 low, rear axle is a ford 9" with a spool and front axle is hp ford dana 60 with 5.13's tires will be 39.5 PBR's right now 38" tsl's
specs of the rig
