Looking for a replacement steering box for my 2004 Dodge 3500 (SRW) 4x4
PSC, Redhead, Borgeson.....Mopar?
Has anyone considered running hydro assist instead of spending the money on a high dollar steering box?
Still $$$ into a box, but the parts store rebuilts just have new soft parts. The same slop from worn hard parts exists in them so a more expensive box from one listed in the OP is kind of necessary.I went PSC simply because I'm going to put a ram on the truck. All the other fixes are to try and help the sector shaft deal with the weight of the engine and wider tires we inevitably put on, a ram is going to help that better than anything else.
I just used the same $10 pitman arm puller I've been using for years. It's a little thinner than factory from grinding to pull pitman arms on my Chevy and a little wider than factory from grinding to pull pitman arms on my Dodge but it never fails to work. You guys have a lot of salt on the roads or something?I believe I had to buy a Snap On CJ119 or CJ119A pitman arm puller last time the arm had to be removed
Normal puller broke and there wasn't enough room to seat the pullers jaws
