convert dually 14 bolt to single wheel hub
1 reading
9.3K views 5 replies 6 participants last post by  cj8scrambld
#1 ·
has anyone did this have a 80 CHEVY dually axle 8 lug 1 ton in my yj....rear tires in too far....what hub do i need or bearings to space it out more????any help would be great thanks JEEPMAN
#3 ·
This is exactly what I did on mine. Talk to ruffstuff for the weld on brackets. They don't make one in the exact tube diameter of the 14b, but that isn't too hard to deal with, just get the one that's a tad bit too small.
As for hubs, any SRW hubs will work, except make sure you don't get one of the hubs with the slip over brake drums on the somewhat newer trucks. When I went to the junkyard to get mine, I had to look through almost every truck they had before I found a set of the older style SRW hubs.
This post has been deleted
