Cummins Swap into 2wd 79 F100
1 reading
11K views 13 replies 11 participants last post by  FirstRam
#1 ·
Hey guys, I received word I will be the owner of a 1977 F100 2wd w/ 460 motor, I have been keeping alive in my barn for a cousin who bought it an got in over their head. I have been wanting to tinker with it but held off until the inevitable occurred. I should get the title in the mail any day now.
The truck is in decent shape mechanically. All the bells and whistles work, the engine is original and could use some tlc, but i haven't looked into it. The body has some substantial rust damage (she bought a rust belt truck) but nothing I couldn't patch and fix and the frame looks good, wheel wells and cabin corners coupled with arguably the crappiest body work I have ever seen with some candy paint slathered over everything to ensure rust bubbles.
I also own a 1995 F7000 dump truck with a 12 valve cummins with 89,000 on the clock. I bought the truck for a business and business went the other way, never wanted to sell it as there is nothing wrong with it and its a good back up plan.
I have the room to pull the ford apart and swap in the cummins, Ive read a thread where a guy did the exact same thing with an old school bus.
I have read I need to find a 4x4 73-79 ford to convert to 4x4. Cut the front of the frame off in front of the body and weld on the 4x4 frame. BUT since my plan is to throw in an industrial motor, does it make sense to go through all that trouble since I am guessing the motor will require major cross-member relocation, new mounts and reinforcements etc.
If my plan is 4-6" of lift, a 35 inch tire, Would a better plan be to chop the front frame off completely and fab from tube steel or heavily reinforce the existing frame and salvage what I can.
I would plan on swapping in some beefier axles etc. And am assuming this is a no specific timeline project, but definitely a doable one.
I was thinking a 4x4 conversion simply because of the fab going into the frame would be so invasive, why not make a 4x4 out of it. Otherwise I wouldn't hate to have a 2wd tow rig, but It would check a big box if i can make it 4x4 with a manual.
This swap is on the drawing board simply because I have some key components on hand gathering dust, I'd need to source a T-case, driveshafts and axles but i think this could happen, however my experience ends at changing our major components. I have fabricated minor things and worked in a fabrication shop for a few years so I can, and have, welded minor parts before.
Thoughts?
#2 ·
Couple of suggestions for you.
1st, the 12/24v cummins has been swapped into a wide variety of things and most of those are well documented on-line. Spend a lot of time searching.
2nd, unless you have an emotional attachment to the truck, sell/part it and start with one that is closer to your wants already. You will be money and time ahead, especially since the truck you would be starting with is a rust bucket.
#3 ·
F100's could come with factory 460's??? That seems odd...
I don't have experience with a 6BT in a '70's model Ford, but I am intimately familiar with both in their own regard. The 6BT is tall...very tall...and the industrial pan just makes them taller (the industrial pan is deeper than the Dodge pan everywhere). Is your 6BT front sump or rear? The pan will mount either way, but you'll want rear sump configuration for your F-100, thus you may have to source a Dodge pickup tube if yours is front sump. The crossmember is pretty high and forward in the F-series, but could possibly be avoided with a Dodge pan and body lift. You may have to clearance the crossmember a little. I would not go through the trouble of splicing a frame. Worst case, find a similar year model F250/350 frame and swap it in for marginally improved beef at best and factory front leaf springs (assuming 4x4 frame). A Dana 60 front axle will be the best bet, and I'd look at Dana 70/80, 14 bolt or Sterling 10.25 rears for adequate tow pig beefiness. Or, if you keep coils, pick up a set of Super Duty axles (D60, Sterling 10.5, metric) and enjoy beef, better turning radius and smoother ride at the expense of having to get metric wheels. Depending on which transmission you run with (I'm assuming the F7000 probably has a large Eaton or Allison) you may have to resort to body lift of doghouse modification. A divorced NP205 would be easiest for 4x4 in either case, unless it's an Allison 1000...but then it gets pricy reconfiguring to 4x4 tailshaft and such if you want to go married t-case. I've seen some home brew tails for putting married NP205's to Eatons, but it looks like a lot of work for little gained.
There's plenty more to learn on the matter, but it can be done with minimal fabrication if you do your homework and gather the right parts. Good luck!
#4 · (Edited)
An old F100 frame is probably not the best starting point for a heavy engine in a tow rig. My ''79 Bronco frame was paper thin from rust in the whole back-half.
I would look for the heavier gauge F250/350 frame w/cab (for prototype/fitting) and build that. Then do a body swap at the end.
EDIT: The F100 weight tags could be a problem.
#6 ·
Great thoughts. I was searching around last night and found a rig where the guy swapped the body on the F7000. From what I am gathering, I am close but in reality the two trucks components don't go together like ham and eggs, like i originally thought. Ill post some pictures tomorrow of the two trucks and get specifics on all the components. I have 2 young kids so loading them up in either truck is a no go, but in 3 years they will both be legal without safety seats, just regular belts.
My end goal is to build a pickup DD that can tow my farm tractor too and from my farm to various hunting leases, and retire my 4runner to offroad duty. Figured my cummins was to nice to waste. I cant afford a new F-250, and I want a one off rig, figured a cummins swap was the coolest thing around. Ill get some pics gathered on what i do have and forge a path from there. Everything Im reading tells me the F100 just isn't the right truck to put the motor in. I have found that most recomend getting a dana 80 rear and dana 60 front axle and the NP205 t-case, so the hunt begins for those parts, or a donor with those parts. I think the advice i get from the posted pics will point me in a better direction. Thanks for the responses!
#8 ·
use the 2wd frame and just hang an axle underneath it. Thats what im doing on my truck. 77 f250 2wd with a 12v and 05+ super duty axle, front suspension and steering. Using 1st gen dodge (cummins) motor mount brackets and prothane jeep motor mounts the motor bolts in with just drilling 4 holes. If you keep the truck 2wd you would have to notch the oil pan to clear the steering linkage.
#10 · (Edited)
Concerning the F100 frame, The frame should handle the weight of the Cummins…..so long as you don't intend to use this truck to haul or pull anything big and heavy. The factory frame was designed to support about a 1/2 ton capacity with a big block gas engine under the hood. You'll be dropping the heavy 460 for a heavier 6BT, but you'll only be adding about 600 more lbs, which should be well within the frame's capacity.
I would be concerned that the frame was exposed to salt. You said the body has substantial rust, I would suspect that the frame could end up being a lot thinner than original since everything rusts at the same rate under the same exposure. Frames are quite a bit thicker than sheet metal, but it doesn't mean the frame won't rust. They can thin out and still look alright. For that I would consider another frame.
If you're converting to 4x4 anyway, I would use the F700 frame (F7000 ? is there even such a thing?). The frame is a lot beefier and should already have a front leaf spring suspension
….Then again, if you got so much body rust, I probably wouldn't bother using anything from the F100 and just shorten the frame on the F700 and convert it to 4wd. You could sell off the 460 to recoup some of your expenses, but you probably be light years ahead, by turning the F700 into your project truck, since the engine is already in it. And think, with minimal lift, those huge front fenders will clear 42" tires
Ed
#12 · (Edited)
460s are 700ish pounds depending on accessories. In a Lincoln, expect 720, in a race car with aluminum, expect under 550.
Cummins is 1200 lbs. It's a lot of weight but I have zero doubts an F-100 frame could handle it. It's just not going to like the beating you'll put on it compared to the thicker chassis of the F-250+ and that truck will never tow like a larger pickup would.
Personally, I'd just slap some cheap flat tops in the 460 with a straight up timing chain and recurved dizzy, port the exhaust side on the heads, and enjoy your tire burner.
Build the F-700 into a kickass work truck/ hauler. Find a Bronco or an 86-96 F-350 for a wheeler and pull that behind the 700.
An F-700 with Rockwells or whatever the Meritor 4x4 axle up front they came with would be cool as fuck riding on big rubber though. Be fun to get some milsurp tires on it and trim where necessary.
