D44s Vs. D60/14B for a TJ
3.7K views 48 replies 24 participants last post by  plasticmanhey
#1 · (Edited)
I have a 99 TJ, with the factory Dana 44 rear and Dana 30 Front. I am trying to decide if I really need to go with a Dana 60 front 14Bolt rear or Should I just go with a built Dana 44 Front and upgrade the Factory Dana 44 Rear.
I currently have a short arm 4" lift and 33s. Will be upgrading to about a 6" lift and 37s. Long arm of course. The Jeep is my daily driver but it sees some decent trail time. I mostly run some light trails and some mud. Everything is muddy in Oregon. Anyway I realize that for a daily driver that the D60/14B is a bit overkill but I just don't want to have to worry about breaking stuff...since it is my daily driver and I need to be able to drive the 15 miles each way to school and back.
I have been doing alot of research and it seems like I am right on the border or needing the larger axles, but since the Jeep will see little to no rock crawling and is kinda underpowered I am thinking a Dana 44 might just be enough. Also I really don't want to deal with having to narrow the 1ton axles, but that may end up being what I need to do. Let me know what you guys think.
Ohh also I have the factory AX-15 trans and NP231, soon to be atlas or Stak :)
Thanks in advance....and sorry about the long lead up. :D
#38 · (Edited)
Nope live in Corvallis on the south edge of town, school in Albany. I am in the welding program at the community college, while also working on a business degree. Hopefully next year I will be able to transfer to OSU to shorten the drive.
Thanks for the link...looks like I have some reading to do.
#43 ·
I have been looking around it is true that it will cost about $4,000 to do everything I want to. And that I could probably get 1 tons for around the same, and maybe even cheaper. But I am able to break up the cost a lot more by going with the 44s front and rear. I don't have access to a ton of tools or easy access to a welder, press, lift etc. So by just buying the D44 front for $1500 new, I can toss it under the front in an afternoon in my driveway. Then as I get more money I can throw in the rear locker and shafts with new R&P. Then a while later I can do the same in the front, with virtually no downtime.
I appreciate all the input guys. Thanks again.
#44 ·
You're probably not going to get a set of 1 tons for $4k. I have most of that invested in my front alone (and I had a sponsor for some stuff). Figure $1000 for locker/regear, $1000 for the front axle, $800-1200 for steering, $300 to clean up the brakes and you've eaten up most of that $4000 right there. Upgraded knuckles, shafts, switching to 8 lug wheels, etc., will all add to the cost.
Axle swaps should be carefully decided and thought out. I suggest you figure out exactly what your goals are right now and save until you can get there. There is no shame in building a pair of axles in your garage, saving until you can get what you want, and swapping them in when they're 100% ready. If I ever build another rig, that is exactly what I will be doing--build axles, suspension, choose tires/wheels and install, followed closely by cage/protection, and then engine swaps and/or transfer case upgrades if necessary.
#47 · (Edited)
Well I think I have finally decided on getting a Dana 44 front axle assembly from NorthRidge4x4. It come with AlloyUSA 30 spline chromolly axle shafts, ARB locker, and R&P all assembled for about $2500. For the rear, AlloyUSA 33 spline chromolly axle shafts and Detroit for $1000. In total I am lookin at about $3500. Not to shabby. Certainly not as great as a D60/14B combo but should work great for what I want. Now I just gotta figure out how I am gonna come up with $3500 after I buy a transfer case...hmmm.
