I installed a fitech go efi kit onto a chevy 350 in my k5 blazer. Im having trouble starting the truck, once its started it runs fine , but its like starting a carbed truck on a really cold day. Lots of cranking to get it fired. It is inconsistent and sometimes will die.
I did not use the fuel command center and instead chose the frame mounted fuel pump kit. The pump is mounted below my fuel cell and the correct distance (not to far from the pickup) from the fuel cell . The pump is grounded per there instructions to bare metal using the bracket that holds the pump. Ive sprayed around the intake checking for vacuum leaks but have found none. I can run and drive the truck at operating temp. Then shut it off , and it will take forever to fire back up like a real bad cold start. Any ideas what can be causing this?
