I have an LQ9 swapped into my K5 blazer with 15k on it since the swap. The truck generally runs around 200 degrees but has recently been spiking up to about 210 and above in warmer weather.
Nothing I was too concerned about but wheeling his weekend I hit 250 during a sustained loose hill climb (20 min of climbing and idling)
My griffin radiator with dual spal fans and shroud has fluid up to the steam vent port. Everything I fill it above that it will puke fluid into the over flow and being a one way cap, the fluid settles back down to the same spot.
I ran it without the cap on for about 15 minutes (at idle) yesterday to get the system burped and added fluid again. Driving around it puked fluid again and settled back down to about 2-3 inches below top of cap.
Do I have an overheating issue?
How hot is too hot?
Any process for burping better than others?
Thermostat is working, vent line is hooked up and moving fluid.
No leaks unless it pukes out cap.
Any ideas?
How hot is too hot?
Any ideas?
