I weighed an AAM 11.5 rear axle
7 reading
11K views 22 replies 6 participants last post by  PFC Lug Nut
#1 ·
The axle is a 2003 out of a 2500HD with G80 differential. The complete carrier is in with the cover on. Hubs on, axles in. I used two scales to verify. The orange scale reads 323.5. blue scale reads 345.0
I did not weigh it complete with disc brakes. Wish I had.
#6 ·
just wondering why you went with the early small tube version ? is it the exact width you need ? got it for a hell of a price ? u joint size matched what you need ?
the later versions like on the ram 3500 have 4" tubes , more gusetting on the pumpkin and the 1555 joints. but maybe theyre harder to find or expensive or the wrong width for what you need
#11 ·
nice project. if you ever try anything else , the elocker from a 14+ power wagon 11.5 may drop right in yours. its got a torson built into the locker carrier. the front locker would for sure fit yours but thers no torson on it. rcv has one piece chromo shafts if you didnt know
Thanks, I would prefer to have an E-locker, or a Detroit locker etc, instead of the G80. I will look into it.
#12 ·
I am narrowing the 11.5 rear, and made my own jig. I did not want to pull the carrier as it is perfect .
I bought a longer used axle shaft And cut tHe flange off. I took a spindle nut, and welded a solid round bar to it. I have a lathe, so I turned it, and bored it slightly over size of the ankle shaft diameter. There is very little play, a piece of .003 shim stock wrapped around the shaft makes it a perfect fit.
Since the shafts splines engage the side gears, it does not spin freely. By leaving a little wiggle room, as I tack weld and finish weld in stages, the wiggle room will stay the same if the tube does not warp.
#14 ·
The tool I made worked perfectly. The original axle shaft can be used, the flange cut off. As in the line up tools that can be bought, the tool I made is simply an indicator to detect ant warpage. I used very tight fit sleeves, and plug welded them on both sides of the joint. The sleeves help to counter any warpage. I will post pics soon as it is in the painting process now. I am going to use the original axles, bore out the flanges for a press fit on the shafts, and add an outside tube on the flanges, to get more surface area to weld for strength.
#15 ·
Here it is finished. The line up tool I made to narrow the axle worked perfectly. WMS to WMS is 57 inches, same as a CJ5. It will be a two seater. I decided to use hydraulic assist cross over steering and make it street legal. It will get headlights anyway, has the E-brake, so, no big deal. Whether or not I will ever street drive it, who knows.
It is beefy. It will have chromoly axles, made by Dutchman.
#23 ·
Built a bumper, 1 inch bolts for sling attachment, Griffon radiator and mesh guard, almost finished building the truss for the widened front axle. Engine up higher with the stability from wider axles. Fitting the Patriot side pipes.
