I am fixing to start my long delayed TH350 to NV4500 swap on my 82 chevy 4x4.
About two years ago I had the transmission rebuild and the person that performed the work advised me to use Automatic transmission fluid instead of the recommended high dollar stuff. He told me he has been rebuilding all kind of heavy duty transmissions for thirty years now and for what I was going to be using the truck for the automatic transmission fluid would be the best way to go. His reasoning was the automatic transmission fluid now made will not attact the sinkos and will reduce the power required to turn the transmission. He said unless this transmission was going into a one ton diesel that does a lot of heavy duty towing the high dollar stuff is just overkill with no real advantage.
I also have a friend that was a service manger for Ford for 20 years and has rebuild all kinds of transmissions (Some transmission larger than my 350 engine.) He agreed with the automatic transmission fluid recommendation and said he would use Mobil 1 Synthetic ATF.
Has anyone every used automatic transmission fluid in their NV4500 and what type did they use?
