I've searched and have not found this specific issue here and can use some BIG help. I have a 2002 Jeep TJ.
Been building slowly and currently have Rubicon Express 4.5" SA kit
35" MTR's
Winch, Swing out tire carrier, skids on everything imaginable, etc.
I have been having intermittent brake failure since I've owned the jeep but could never figure out why. When I would take the Jeep in to a mechanic they always appeared to be working just fine. The intermittent issues have been there since the jeep was stock. I realize all the 4x4 stuff adds weight, etc. but the same issue remains.
In 2005 I installed slotted rotors up front. Thought that fixed it- nope.
2008 I installed a Navaho brake booster and thought it solved the problem. I loved the response the Navaho had when everything was working BUT, still had intermittent failure.
2010 did an SSBC rear disc brake conversion. Didn't help either.
Finally 2 months ago the failure became constant. A Buddy of mine said the rears did not appear to be working at all.
Found a R rear crushed brake line and a whole lot of crud in the R rear brake.
Fixed the brake line, cleaned out the brakes, rotors, calipers, etc.
Still no improvement.
So, New Navaho Booster. (Chevy S10)
New Chevy 1 ton MC (large bore) and Prop valve as suggested by SSBC. Not that either.
Another new 89 Suburban MC (smaller bore) and Summit adjustable prop valve.
Still the rears are not working.
WTF!!!????
We will be tearing the rear brakes apart and changing pads, inspecting calipers, rotors again.
Any ideas here???
35" MTR's
WTF!!!????
Any ideas here???
