Here is what i'm leaning towards.. I wanted to get other opinions before I started to cut up the tires... Any input will be appreciated.. Thanks
David
David
Thats not my Jeep.. I was using the tire for something to draw on. The inner lugs are not grooved on those tires.CA_YJ said:I've never been a fan of boggers, but we wheel in different worlds...but me likey dat groove pattern.
Why ask...you already cut the rear like that. I dig it though
I like his idea but i would goove the small treads strait up and down opposed to diagonal because the whole reason for gooving BOOGERS is to gain lateral traction. I would also like to see someone take more rubber out(more than just a 1/4' groove) on the lateral cuts.Lowrangerider said:I am no grooving or tire tread expert but maybe it would be better to have the grooves leading to the outter edge so they help to push water and mud out of the tread instead of into the center. Just an idea...
same pattern but the small lugs arnt grooved, look closerCA_YJ said:No...the REAR tires appear to already be cut with that same pattern. Or am I seeing things?
Actually, Boggers don't self-clean as well as many other tires (TSL's included). They require SPEED to self-clean, like paddle tires. Besides, keep in mind they're the first tire designed SPECIFICALLY with grooving in mind. The original IDEA was for the smaller lugs (along with everything above the cords) to be removed. Me being a mud guy, the design shown does nothing for me, but that's probably inconsequential to the thread starterpaulevans76 said:yeah but this way it seems like it'll grip better. they are friggin boggers, the mud and water will get out of there on its own :flipoff2:
Tires look good !! I notice you have the special blue tinted edition boggers... I get that around here where there is slimy clay/limerock. Where in the south are you?P&T Jeeps_ said:here's what I did to my Boggers. It made a world of difference on side hills, they are kick ass tires even more so now!![]()
if you cut the lugs twice I think you might leave the pieces too little and chunk them off.
Louisiana. and boy do those things get bright ass blue sometimes! any grooving will definitely help, as I'm sure many patterns work, but I cannot stress enough how satisfied I am w/ the before & after of the grooving. I did my brothers for his XJ the same way and he noticed a big difference also.tunedportcj5 said:Tires look good !! I notice you have the special blue tinted edition boggers... I get that around here where there is slimy clay/limerock. Where in the south are you?
