I know I have read articles on this before. Can someone shoot me in the right direction. Want to lift a TTB without the brackets. I have seen writeups on cutting and turning the front end instead. Thanks
goodbye track width...hello shitty handling
Yeah I was just gonna say good bye U joints...
I've owned 2 Autofab equiped TTB trucks. An Explorer and my current DD/toy a fullsize Bronco. Both had what many refer to as "cut and turn" axle-housings. The housings are modified at the lower ball joint to correct camber. contrary to what some are saying, these trucks work great and have never given me any issues even during brutal off-road punishment. Yes you lose a bit of track width, but they handle great on and off-road. I regularly use 4wd when driving hard and I've never had a problem with u-joints. I've also never had alignment issues. In fact, both of my trucks have been within a half degree ideal alignment specs with zero degree eccentrics. Tire wear has always been normal as well.4 shocks per wheel:shaking: I just lost all respect for that company
a self leveling airbag system would be great for a TTB to keep the camber in spec with varying loads
As for the Ujoint, I'm sure they will encounter more stress than normal but it all depends on where you cut and how you locate everthing. This can be done with out creating sevear angles on the axle shafts and ujoints.
