tubing roller vs. tubing bender
1 reading
32K views 11 replies 7 participants last post by  scramblerj
#1 ·
I want to know about tubing rollers vs. tubing benders.
Are pipe benders the same as tubing benders?
I want to bend some 2" X .93" DOM for a roll cage. I will bend lots of sacraficial tube before having anything I expect to actually use. I read the Harbor freight bender and roller review and want to go that route. Should I get both?
#7 ·
2" x .93? That's almost solid 2"! Did u mean 2"x .095"? Dom is stronger than hrew but .095 is thin. The most common size is 1.75" x .120 Dom for roll cages. .250" wall on the rock sliders or other high impact areas.
Just an opinion.
I built my cage out of 1.75 x .095 hrew and regret it. I don't feel safe inside it. The tube bends easily. I will redo my cage when I can afford it.
#9 ·
why is HREW out of the question? the wall thickness is pretty important as it helps the structural integrity just as much as the diameter is. 2" is a bit overkill but whatever blows your skirt up. I used 1.75x.120 wall HREW and I feel it is sufficient. In rock crawling most of your roll overs will be low speed (unlike drag racing) so as long as you have a properly built cage you will be fine. if you just throw together a bunch of tubes with no clue what you are doing and cannot support the structure even DOM will fail.
