I was looking at picking up a used full floating rear axle kit for a 1974 Dana 44 CJ5 axle. The problem is one of the wheel hubs is bent beyond repair. The hub I need is the one with the 6 lug bolts thru it not the 4 wheel drive outer hub. Warn no longer makes these kits and I was wondering if anyone knows if Warm built the own one off wheel hubs or did they use another more common wheel hub with the 5x5.5 pattern. Like a mid 70's Dodge or Ford with a dana 44 front axle?
Thanks
Mike
Thanks
Mike
