Teflon/Braided brakelines throughout a buggy?
5.6K views 16 replies 14 participants last post by  AddictedOffroad
#1 ·
Anyone running all Teflon/braided line? I searched, but only saw a thread back in 2006 with mixed reviews.
I am running all -3AN lines from a dual Wilwood master cylinder with single pedal. I am setting up cutting brakes just in the rear for front digs mainly. So, I need to run two dedicated lines to each caliper. That means roughly 96" of line to EACH rear caliper. Front will be a single line to the axle down an upper link, and then T'd to each caliper.
Obviously, soft line is easier and I already have enough to do it. I may run hardline from the MCs to the frame and then soft the rest of the way. Just curious who runs something similar with success.
#6 ·
All plastic in mine now with no problems. I carry a couple spare couplers and some line just in case I need to fix something. If a line brakes I have 1/4 turn ball valves that I can shut off the front or rear. I also use them for line locks.
I ran the -3 braided before, but hated dealing with the braid at fittings.
#10 ·
all plastic in my last buggy. i would always get leaks at the calipers. plenty of slack in it. just with 50 degree steering i think the constant twisting would cause it to leak at the ferrel.
all stainlees/teflon in this buggy. no issues.
#11 ·
I've got 2 plastic kits sitting in my tool box. When I built my buggy I was going to use that stuff, then a buddy offered to do it all up for free with braided lines, so I obliged. :D
Every time I open the bottom drawer of my box I wonder how good those lines would have worked though, there's several success stories out there.
#12 ·
At one time one of our Flatfenders ran a single flowerpot to all the disk brakes. Just before heading down Black Bear Pass, we decided to bleed the brakes. The single Stainless/Teflon hose exploded. No bends. No movement. But WTF...In the middle? We got lucky. Now it is Stainless Steel tube with the Stainless/teflon short hoses. An Aerostar dual master was also plumbed in.
You may not see damage under the Stainless wrap. Especially if in an area where rocks can kick up and pinch it.
Dumb was not having a dual master for so many years!
#14 ·
Run braided stainless at the front calipers from a RE kit and Teflon rear line from Speedway. Teflon line has been there for 2 years now with AN3 fittings and still looks new. Braided stuff is dirty as hell and hard to keep clean. After I redo the brake lines again I'm going all Teflon up front down the link from a small hard line at the master. TJ brake lines route all the way around the frame so I'll be cutting that off and running a single line down the upper link. I've found that the more hard lines you have, the more prone you are to kinking, leaking, and buying more line over and over again!
