97 TJ 4.0 5 speed runs great, doesn't burn or leak a drop of oil, new exhaust manifold with 2 1/2in. bluetorch fab front fenders, rock sliders, and comp corners,red top optima, new warn 9000xi with winch rope,full soft top,and bikini top,atlas 4.3 passenger side drop t-case with 32 spline input/output shafts,front driveline is a 42degree cv "BAMF" with 1350 joints,rear is also a 1350 joint shaft, chev dana 60 front with an arb 5.13's, new nitro 35 spline chromally shafts with 300m excalibur u joint's, 300m drive flanges,new wheel bearings and rotors, new full hydraulic steering with a pse double ended ram, 3 link front with 16" FOA coilovers with all ballistic fab bracketry, 14 bolt rear with an ARB 5.13's disk break conversion kit, new wheel bearings and seals, triangled 4 link with 16" FOA coilovers, 17" KMC aluminum bead locks with new 39" BFG Krawlers red label (only 4 trips on new tires) 1 brand new spare, not even mounted. most everything was bought brand new... not sure how to post picture's but its also for sale on
http://www.nw-wheelers.com/forum/showthread.php?t=54199
also theres a build thread in the garage section under "97 1 ton TJ build" or
http://seattle.craigslist.org/see/cto/1879464251.html
$14,000 obo/part trade section under "97 1 ton TJ build"
Mike 360-410-8120
Mike 360-410-8120
