My 3-ton Craftsman floor jack is low on oil...I went and got jack oil at my local parts house, but I can't figure out how to fill it! :mad3:
OK, it has a fill plug half way up the body of the jack just like my cherry picker and press...SOP on those is to pop the plug when the ram is all the way down, fill til it seeps out, let it sit a few minutes, replace plug, and you're ready to go. The floor jack ram, of course, works on its side. Sooo, first thing I tried was to stand it up (like you'd use a regular jack) and pull the plug, only to have oil run out even though it was low. Obviously that was not the right position. So next I laid it back down on its side, turned it 90 degrees (so that the fill plug is on the side of the jack rather than pointing straight up as it would be installed on the jack assembly), filled it, let it sit, put in the plug, turned it as it would be installed, and tried it...and it operated just like it did before I put oil in it.
Am I missing something?? It has been seeping for quite some time around the plunger that "jacks" the ram, but it really crapped out shortly after I lifted the front of a diesel Super Duty...yes, a SD is heavy but picking up one side at a time is surely less than the jack's trated capacity. I'm just trying to figure out if the ram is shot or just low on oil...a quart of oil is cheaper than a new jack.
Any help is greatly appreciated.
