ok, so is there a kit out there to move the VSS from the rear axle to the transmission output shaft? because if I go with a Ford 9" swap out back, i would clearly like to have a working speedometer. I don't care about the ABS, as my ABS light has been on ever since my dad had the truck, which he bought new. It came on when it was two years old. turns out the bolts that hold the TrueTrac together (installed by the Ford dealer he bought it from) all lossen up, scored the bearing cap, and broke the head off some of them. the bolt head then rolled around the diff for 4 more years, until I wanted to see what the hell was wrong, and found that the tone ring was worn to nothing. so i replaced the tone ring, and loc tighted all the bolts. then they loosened up again, so I had my mechanic do it. now, the two lights for the ABS and the parking break go on together shortly after I drive down the road, and randomly turn off for about two minutes or so. I know the parking break is off, so i'm guessing its just stupid dash light malfunctions, cause I check the ABS in the snow when I'm driving around when I get bored, and it works. either way, I would need to relocate the VSS, and would like to know if that is doable.
