Has only 14,800 miles
This rig will drive 80 on the freeway with good manners and crawl like a buggy, have driven daily
Front and Rear DynaTracs Pro Rock D 60s 513 gears with ARB lockers with short hubs and the all the good stuff have build sheets, only about 300miles
Oversize (the large HD one) ARB air pump will fill tires also with air chuck new
New Paint
5 on 5.5 with large dodge brakes on axels only about 300 miles
Stainless steel brake lines
HD custom made tie rod with heims new
High steer kit new
Gen Right dropped and twisted pitman arm
Gen Right dropped kit for Track bar
Rear bump stops
4 Limiting Straps front and rear
Front Easy disconnect sway bar hub type
Coil over Shocks front and rear
Articulation is SUBURB
Lifted about 4” with 1” body
Rubicon Long arm Kit
New Atlas 2 sp with 4.3 to 1 low only about 300 miles
Custom built HD drive lines and U joints front and rear
CB controls in hand set with external speaker
Master Craft Seats with 4 point harness
Small DC AC converter to recharge cameras phones etc.
Good Stereo with, amp, USB port, for IPod and water proof Boat Speakers
Custom made Poison Spyder Roll Gage
Poison Spyder 3/16 body armor rap rear
Poison Spyder rock sliders
Poison Spyder front and rear fenders
Poison Spyder bumpers
Poison Spyder front stinger
GenRight Rear Stinger and 40” tire carrier
Custom tool box in back
Steel gas tank protection
37” BFG KMs
Spare tire same
Trail Ready 17” Alum bead locks
Custom top with blue strip
Custom made tire cover for 37” tires
Frenched LED tail and turn lights
Two battery system one to run on and one that is charged but isolated until you may need it. No load on the spare great for stereo on all night and use other to start in morning
9.5 steel cable Warn winch
Stock Engine 4.0 with cold air and chip
Stock Trans with OD
$29,500 or make a reasonable offer Bob 702 985 8080 Las Vegas RQMoore7@yahoo.com Can send as many pics as you want.
This jeep in stock form goes for $14,900 today and the axels and transfer case were Apx $16,000 alone just for the parts. Great turn key buy. 58 cents on the dollar.
New Paint
High steer kit new
Rear bump stops
37” BFG KMs
Spare tire same
Stock Trans with OD
