22r to 22re conversion question
3.2K views 7 replies 5 participants last post by  gnob
#1 ·
I am gettting ready to do the swap in the next few weeks and i have a few questions to ask....First off i am running the gm ignition module and a push button start and a gm 1 wire now and i wont to leave them the same....I have everything i need including all the interior wiring.....How can i hook up the conversion to what i have know....I do not have a toyota I have a geo tracker with a toyota drive train....84 or 85 22r with the single row timing chain...
#2 ·
for some reason i was under the impression you had this swap finished :confused:
read the ****ing faq, there is a thread in there about the gm ingition module. if you also have all the wiring you need, then it sounds like you have it figured out.
#3 ·
well i just read the title, the gm switch listed in the faq wont work if you are running factory fuel injection, why dont you want to run the toyota system?
#6 ·
I did the search and never found anything doing the gm ignition module and a push button start with fuel injection and how would i get it to work with what i have.....U asked why i ant using the toyota ignition I dont have it and all i have is the gm module and i really do no wont to fight with more wiring in the cab area....I wont my 4x4 to be min wiring..
