33" tractor tires for 15 or 16" wheels
1 reading
89K views 21 replies 15 participants last post by  4xsteve
#1 ·
anybody know where i can get some?taking me race jeep to louisiana for tgw and id like to throw on a set of tractors.
#13 · (Edited)
Do not run skid steer tires. They don't flex at all, and will punch out / rut everywhere you drive. You will get stuck often. The side walls are way to stiff.
If you go with ag tires, check out the ag wreckers. That's where I got mine. Also your local fountain tire. I got some used there too.
Also check here they have some info.
http://www1.pirate4x4.com/forum/showthread.php?p=9654187
Front view of my trail spare. Tire is a 18.4x16.1 Rim is 11.5 bead mount surface to bead mount surface. I would go 14" to 16" If I do it over. I have a set of 21.5 x 16.1 that are going on 17" wide rims with weld on beadlocks.
Side view.
My rig is still in the build phase. I will post updates when I know how they do.
Nat
#12 ·
only place my r-1's have any trouble is on smooth rock slabs in creek beds. Ledges are no problem as the lugs just grab and go. But, i think they do fine as i don't hit the rocks much. I ran the long bar/long bar tread for a while, but switched to long bar/short bar treads and couldn't be happier. 100% better traction.
