I'm just finishing a 4.3 swap into my Suzuki Samurai and need help answering a computer question.
Engine is from a 93 s-10 4x4 Blazer. I have completely rebuilt motor all new parts. even replaced all engine sensors.
I'm using a Painless wiring harness. This one.
I'm using GM part #16197427 ecm/pcm. I had no ecm when I got the motor so this is an ecm I got at the wrecking yard got two of the same part #ed ecms.
Problem I'm having is low idle. Its low enuff that the engine will just die without warning. It will run for quite a while then just die it will restart very easy run a while and die again. This is all while the rig is parked.
Engine runs great while driving and I am on the throttle, but once I let off the throttle to to start coming to a stop the idle drops and the engine will die.
I have tried both ecms. one ecms will cause the engine to idle better while parked but will still die when letting off the throttle while driving. The other ecm will idle low while parked and will die once off throttle while driving. Both ecms have the same GM part number and this is the numbered ecm that Painless said I would need for the engine I have.
My question is, Do I just need to get a differant PROM for thr ecm or can I get the PROM reprogramed?
Would getting a new PROM help with my idle problem?
This is the motor in my Samurai.
