5.9 12V ---> sm465
1 reading
61K views 106 replies 30 participants last post by  wcuhillbilly
#1 ·
So my 3+3 is torn down, and I'm getting ready to prep the 12v to go in.
It currently has a crappy auto, with the case on the wrong side, neither the auto or the case works for me in the end.
So, I've been doing some research on putting an sm465 behind it, using the breadvan adapter, which would tilt the motor 8*. If I put the engine in level though, it would clock the t-case up instead. I can upgrade the input for around $120 to the 1.5" heavy duty version, and with the 32 spline np205 coming out of my truck, I believe I have a 32 spline mainshaft I can rebuild a sm465 to fit in the middle, so my question is, does anyone see a reason not to?
I've read a lot of bad things about nv4500s, and nv5600s, and despise autos(we don't have a good history), and I know I would be losing overdrive. I also know that the top speed would suck, the truck has 35s and 4.10s, but on the other hand, it should have all the gearing and power in the world to haul anything up to about 60mph.
#3 · (Edited)
I'd agree with that.. No way i'd put a diesel with a 1:1 tranny.
Edit: cant you swap in the dodge tranny for the time being? you wouldn't be able to run a front shaft but i'd think driving down the road in 2wd is better than drivng down the road at 45-50.
I have a 24v/nv4500 that i swapped in. I shift into OD around 45 and when i get to ~70-75 i wish i had one more gear
#4 ·
Clearly you need to send me the truck. I never really liked the 465, due to the wide gear splits. It's really only a 3 speed with a deep low.Unless you dropped to 3.08's or something, I think you'd be better off with a 5 or 6 speed. Investing any money in a 465 to work even in the interim, is a waste I would think...
#12 · (Edited)
Let me guess; you either broke the input shaft or the 10 spline output shaft, right?
spidr: you can't use the 1-1/2" input shaft with a standard GM bellhousing setup because it's too long. Also, the biggest clutch you can fit on a GM flywheel is 12", which is marginal for a 6cyl. Cummins. I'm using the Dodge adapter set with a custom 13" South Bend clutch.
#19 · (Edited)
And, you know this from experience, right? :rolleyes: I love it when people on internet forums make statements that have zero basis in fact :shaking:
It's rated for 450lb-ft, just like the NV4500. The main limitation is the 1-1/8" input shaft. Switching to the 1-1/2" input shaft increases the torque handling capacity big time. The rest of the trans has no problem handling huge amounts of torque.
#29 ·
I didn't realize that was you. I've actually had that bookmarked for quite a while.
The countershaft in an overdrive trans I hadn't actually though of. Kind of makes me lean towards the 4 speed that I know though. Thank you for some insight.
And to clarify, the strength of the trans is NOT something that I'm worried about. There are other parts of my truck that would blow up first. I have some experiance with them.
#32 ·
Yup, that's me. If you're interested in doing the 465 conversion with the Dodge parts I can machine up an extra spacer ring (locates the 465 in the larger diameter 4500 bellhousing) for a reasonable price. Everything else is minor fabrication, although some TIG welding will be needed. I will be doing that part of my swap in the next week or two and as usual I will post up pics in my build thread. It's actually pretty simple stuff. The only part that's tough is paying for the clutch :D
#34 ·
He also agreed to it being inputs or 10 spline outputs. I would be upgrading to a 1.5" input(from 1-1/8") and running a 32 spline output, which is a serious upgrade.
I've been told a lot of things are dumb ideas until I do them, but if the only reasoning is the lack of overdrive, then I'll regear. So far that seems to be the only reason to spend the $1-2000 on a 4500 or 5600.
#35 ·
Whats wrong with the Dodge OD? I am looking for a 12v with a pre 96 auto and OD for my chevy truck. I need to get a 4wd so I have the transfer case too. Im doing the same thing as you did. Just my truck was near free....... Looking forward to seeing how your swap goes. What crossmember are you using? Custom or Avalanch or?
#37 ·
I don't feel like spending 5 grand plus on an auto to keep it alive.
And "keeping it alive" is very relative with automatics. You can beef it up so it doesn't break outright (maybe) but what will it's lifespan behind a modded engine be? 30,000 miles? 50,000 if you're gentle and lucky? So, every few years you get the privilege of spending another several grand to freshen up your slushbox. Doesn't sound like a good plan to me...
#42 ·
Something else to consider is that the 2nd to 3rd gear split in the 465 is quite a bit bigger than in the 4500, which may be an issue with the narrow power band of the Cummins.
FWIW, I blew my 4500 ~1 1/2 years ago and picked up rebuilt 4500 with the updated 5th gear, etc, for ~$1250 + core. Not sure what is involved in adapting a 205, but I think its pretty straightforward using the the first gen case.
Have you considered a 6-7 speed out of a medium duty?
Pete
#44 ·
Pete
Yup, looked at those, right up to the 10 speed road rangers. I think a 10 speed would be real cool and If I can find one cheap enough, I'll go that way. Likely a much stronger option than anything else being discussed
i think the clutch will be your week point.
you might try flipping a 205 around for a underdrive unit. why not a truck with 2 tcases to match the blazer
It's been discussed before in general, and I know of at least one truck using a 203 as an underdrive, but since this will be the DD and hauler, I don't think that reversing the thrust direction would make for a long and happy living 205. I've thought about dual cases too, but unless I could shift it on the fly, it would be a waste for day to day driving.
#55 ·
what ever nv4500s are awesome the go the OD and are very tough.[/QUOTE]
Wow...........You must be da'man:shaking:
Got anything usefull to contribute, or would you prefer to just keep running your mouth?
#52 ·
I've read a lot of bad things about nv4500s, and nv5600s, and despise autos(we don't have a good history), and I know I would be losing overdrive. I also know that the top speed would suck, the truck has 35s and 4.10s, but on the other hand, it should have all the gearing and power in the world to haul anything up to about 60mph.[/QUOTE]
#58 ·
#62 ·
465, why not????
most people with the 4500 dont tow heavy in 5th any way so not to blow it up.
If your in california you cant to leagaly tow over 55mph anyway.
If it turns out to be to slow, regear the axles.
The early gen one dodges came with an auto and no overdrive. They ran 3.08s in most of them with stock little tires. I would say 35s and 3.73 0r 3.55 would be fine.
and in the end its up to personal preferance. You arent telling him to build a different truck because you think your idea is better, so why tell him what trans to use? he addressed the strength issues, so let the man run his tranny!
#64 ·
47re has a .69 OD At 2000rpms is running 74mph
nv4500 has a .73 OD, At 2000rpms is running 70mph
3035a has a .85 OD, At 2000rpms is running 60mph
sm465 is 1.0, no OD, At 2000rpms is running 51mph
So where does the power band run out on a p-pumped 12v?
#66 ·
Currently it's running 4.10s and 35s.
If I go to 22.5s like I'd like to do, they measure around 39"
Using 39's, it changes the numbers to
47re has a .69 OD At 2000rpms is running 74mph(35's), 82mph(39's)
nv4500 has a .73 OD, At 2000rpms is running 70mph(35's), 78mph(39's)
3035a has a .85 OD, At 2000rpms is running 60mph(35's), 67mph(39's)
sm465 is 1.0, no OD, At 2000rpms is running 51mph(35's), 57mph(39's)
#67 ·
If you go to the 39's you're fine with a 1:1 final in the trans. You would turn 2300 at 65MPH, which is a bit highish but OK. Regearing to 3.73's would put you at 2090RPM at 65MPH, which is a decent cruising RPM, especially for a tow rig. Keep in mind that OD trannies aren't normally rated to pull their full GVW rating in OD, so you would effectively have a worse-geared 4 speed if you kept your current gear/tire combo with an OD 5 speed. Finally, if you gear your setup for a 1:1 trans, you have the option of switching to the 5 or 6 speed FS series Eaton-Fuller transmissions later, which are far better than the NV4500 or Spicer 3053A. The Fuller 6 speeds are also available with an OD 6th, but like any OD trans pulling in OD makes a lot of heat. The 1:1 top gear transmissions are definitely better for pulling weight.
#68 · (Edited)
we have a 12V cummins/465/205 running 4.10s on 33s in a 1 ton dually, it does very well thanks to the gear vendors unit:laughing:
We haven't gone through a single trans or transfer, but on the 3rd GV unit. It does routinely kill dana 70 rear shafts but 4 of those in 350K ain't that bad for the loads it moves routinely.
#69 ·
well a 1:1 tranny would be a very bad idea i have a 03 dodge 3500 srw with the nv5600 and 4.10 from the factory and with the stock tires on it i hated driving it because you have the rev it so high to stay at 70mph i lifted it and put 36s on it and it made it better for driving around and towing i have really thought about regearing to 3.73 just to help out with some higher cruising speeds
#71 ·
I still say just skip the 465 and go right to a 6 speed MD truck transmission. If you get one with a OD gearset you have enough OD to get by with the truck "as is" with 35" tyres and 4.10's as well as deep enough gears at the bottom to deal with 39" tyres and 4.10's with the same caveat that a 7.xx to 9.xx first gear is going to send alot of torque downstream to components that may not be real happy getting hit with that much torque.
#72 ·
The 6 speed MD Fullers with an OD 6th don't have the super deep first gear like the non-OD 6 speeds. 1st gear is 7.05:1, and OD is .78:1.
I agree it would make a good choice, but your argument assumes the OP has 2 grand burning a hole in his pocket :shaking:
#84 ·
There is a dude on Oilburners in the 1st gen dodge section with an MD 6 speed direct trans in his 2wd dually. He raised the cab like 8-10 inches (don't recall right now) to make it fit without severe fire wall hacking, it is kinda silly. He's also claiming some incredible mpgs, but I chalk that up to the internet:rolleyes:.
Travis..
