Not all Clarks have Overdrive, in fact there are only a few. All Clark overdrive model numbers end in VO. There is the 200VO (6.06, 3.50, 1.91, 1.00, 0.80, R-4.87), the 204VO/205VO (6.06, 3.50, 1.91, 1.00, 0.80, R-6.00) the 207VO/251VO/264VO (6.06, 3.50, 1.80, 1.00, 0.80, R-6.00), the 280VO (5.98, 3.50, 1.86, 1.00, 0.80, R-5.04), the 280VOHD (6.17, 3.48, 1.85, 1.00, 0.80, R-6.27), the 300VO/307VO (6.27, 3.51, 1.89, 1.00, 0.80, R-6.27), the 380VO (6.27, 3.55, 1.89, 1.00, 0.80, R-5.11), and the 400VO/408VO (6.17, 3.56, 1.90, 1.00, 0.80, R-6.02). As the numbers increase so will the torque rating (280VO is rated for 330 ft-lbs and the 400VO is rated at 405 ft-lbs). If there is no ID plate on the transmission and you want to know if it is an overdrive try spinning the input shaft and watching the output shaft and remember OD is where you think 4th gear shoud be (all the way to the left and UP).
A much cheaper transmission that I belive has great potential is the Spicer 3053A, the one that comes in 2.5 ton trucks. They are HUGE, but if you have your heart set on a Granny/OD transmission you can't get one cheaper, and they are bombproof. Only problem is nobody seems to have ever put one behind anything but a 2.5 ton military engine. I even contacted Boyce about what I could put it behind and they had no idea. If anyone could figure out how to build adapter plates (tranny to bellhousing and tranny to transfer case) and throw the input shaft on a lathe and cut it down a little someone could have a serious corner on the OD transmission market (at least for fullsizes, these transmissions are HUGE).
Just my $0.02
JYS
