Looking for a little help from some of you 12V guru's.
I just completed a truck build and I'm having some real driveability issues.
The engine in question is a low mileage '97 12 valve Cummins.
It has a BHAF, 4" straight exhaust, 370 injectors, 191 DV's, adj boost elbow,
#4 fuel plate, and a 4K GSK.
The truck runs awesome, but the throttle is extremely twitchy.
Whenever you hit a pot hole or bump in the road that jars your foot the engine wants to take off, then when you lift off the accelerator pedal you get the reverse jolt, which in turn bounces your foot again, and so on and so on. It's especially bad when trying to cruise at a low speed ( I live on a dead end rural road) in third gear...It's so damn herky jerky that I have to gear down and run it up in RPM's.
I did notice when I installed the engine that there was what felt to be a slight bind in the throttle lever on the inj pump...like it was smooth up to a point and then it required more effort to get past one little spot.
Whats causing this?....something going on with the AFC? a governor spring adjustment maybe? is this a characteristic of 4K springs?
How can I retune this thing for controllable power delivery?
Any help or suggestions would be appreciated.
Thanks guys,
Wayne Johnson
Portsmouth, OH
Thanks guys,
Wayne Johnson
Portsmouth, OH
