So I have heard the 9-3/8 rumors plenty of times. Tech Tim tells it well. Well enough I was ready to go pick up a third member and try it out. Here's Tim's story...
BTW: for a cheap big bearing diff case, go pull a 9-3/8" center from a Lincoln. It'll bolt into your 9" housing, accept your 9" gears and has the big carrier bearing. It is still an OE case and is not as strong as the aftermarket billet cases and finding pinion support shims is a bitch, but hey a big bearing diff case for $50.00 or less.......Most people think these are trash and will sell 'em dirt cheap or give them away.... Oh wait did I just let the cat out of the bag??????
...from this threadhttp://www.pirate4x4.com/forum/showpost.php?p=3888965&postcount=11
But then, I was reminded of the other story I have heard about the 9-3/8, by TeenyCar...
Note the double rib with the "corner" in the yellow box. Of course the ring gear is larger as well. The pinion shaft is about 5/8" longer as well. It however uses a short version 9" 1310 yoke, not what is pictured. The carrier bearings are larger as is the pinion bearings. There are crossover bearings for the carrier, but as the pinion is so long and the case different there isn't anything you can do for the pinion side of things. There are also no useable gears for the 9 3/8"
From this great buildup threadhttp://www.pirate4x4.com/forum/showthread.php?t=495084&page=3
I'd heard the longer pinion shaft story before, but not a number to go with it.
So what is the TRUTH? Who has actually put their hands on this stuff?
