So I installed my PSC resi into my steering system today. I have had some challenges with the lines and connections but I cannot get the damn thing to bleed. I figure I must have an open connection in the system somewhere but don't know where to begin pulling things out.
I run from the box to the finned cooler back to the resi and back to the pump and back out to the box.
I am having trouble getting an adequate fitting for the return line on the chevy PS pump so I had to use hose and a barb fitting and that didn't connect perfectly to my AN fitting on my line. I wrapped the barb with teflon tape and as far as I can tell it isn't leaking.
Same issue with the non pressure line on the box. I bought a Russell fitting that I thought would thread, but it didn't
My other issue is the PS pump itself. The ps cap leaks and since the resi is above it my fluid slowly drains unless I use a radiator hose to extend it. Pretty ghetto.
Anyway, here is how the system looks, any one have the exact size on the steering box non pressure port and what fitting to use on the return line on the ps pump that would be awesome. Not sure what I am gonna do about the PS pump cap either, I have tried three and they all leak.
Here is the entire system. As you can see I had to step down the return line on the resi from 10AN to 6AN.
here is the ******* filler tube. Still kinda leaking but only at the top, not at the pump.
here is one of the barb to AN fittings I had to rig. This is on the return line to the PS pump, doesn't seem to be leaking but......
and here is the one on the non pressure line of the steering box.
