Finished the cut and turn today...except for re-welding the knuckles. The pinion angle was set whenever the axle was converted to SOA, so all I have to worry about is the caster angle. Aside from the sloppy steering linkages, the positive caster angle was contributing to some major death wobble.
It's not really going to see too much street time, so I didn't get too picky with the caster angle and did everything on the bench. I started by grinding off all the crap in the way. Removed the steering stops, shock mounts, and brake line tabs. I then ground the old knuckle weld smooth, then ground a groove in the tube just on the differential side of the weld.
I figured my spring perches should be pretty close to level when the axle is installed, so I set my perches to zero.
From what I've seen, most people have been aiming for 4-6 degrees negative caster. I ended up with about 4.5 degrees.
You can see below the difference between the original angle and the new angle. I also made a mark near the cut to show how far it was turned.
I still need to burn them in, but after testing my little 130amp HF welder, I decided it wasn't up to the job and I'll have to borrow someone else's.
