how can you make a starter motor turn backwards without reversing the polarity?
CWToyota said:What kind of starter? To fit what kind of engine?
Some automotive engines (many Ford V8s and probably Chevy/Chrysler too) were used in marine applications... They had reverse rotation camshafts and hence ran counter-clockwise... so they must have used a reverse rotation starter too. :idea:
You might wanna check it out.
nope, starter motor grounds through the housing, it's not like a winch that has a dedicated ground terminal for the purpose of reversing.BobBarry said:I remember thinking how similar the motor on my 8274 looked to the motor on my spare Motorcraft starter. Perhaps you could adapt a three-terminal winch-motor to a starter nose for your application? Can't be much harder than bolting a 203 reduction-box to the front of an NP205. Only problem might be motor-speed.
And when the starter gear engages the ring gear in the flywheel :nuke::nuke:CWToyota said:
You could try to run the wires outside and connect a solenoid pack
I know; that's why I suggested using a winch-motor, not a starter-motor.AZFord4x4 said:
I was under the impression that most marine motors are not reverse rotation? My buddy told me this who works on boats in a marina.RawkRash said:The reverse rotation marine engines I've seen have the starters mounted in the bellhousing facing forward instead of mounted to the engine facing back like normal. They're normal starters, they just engage the flywheel from the opposite direction.
I have seen some reversible brush type motors that have the brushes on a carrier that can be rotated to change the timing. They shift the brushes about 40 degrees or so and that makes the motor run backwards. No rewiring necessary and no switching wires around.
I'm no boat expert, but to my knowledge, most boat engines spin in the standard direction. The reverse rotation comes into play in boats with dual engines to balance out the twisting forces or something like that, so you wouldn't find one in a single engine application.Jason R said:
I was under the impression that most marine motors are not reverse rotation? My buddy told me this who works on boats in a marina.![]()
It all depends what side the builder wants to put the steering wheel. My single engine mopar 440 powered 20' 1974 Century Arabian was RR from the factory. They set them up this way so the prop torque has to lift the driver and the boat will ride more level underway . I had to go to standard rotation so that I could use a roller camshaft and MSD distribtor, and oil pump drive. A 70 qt cooler and two Group 27 batteries were moved to the othe side to help keep the boat level.AZFord4x4 said:
You would need to isolate the flywheel as well!!!sceep said:alright heres how you do it. Run 4 switches between the starter and the battery. 2 for positive and 2 for negative.
switch one: Batt + to switch to starter +
switch two: Batt - to swtich to starter -
switch three : batt + to switch to starter -
switch four : batt - to switch to starter +
turn off switch 1 and 2, and turn on 3 and 4 for starter reverse. Right?
This works if you can isolate the ground from the case, but i have no friggin clue on that clutch thing azford brought up.
:shrug:
