Need the pirate 4x4 expert opinion.
I have a shed at the cabin that I'm planning on insulating, and adding heat to, just to have as a little work shop.
I want to mice proof the place before I insulate. There is nothing worse then hearing mice crawling around in your brand new insulation. So the floor is ply wood, and the beams holding the shed up are on pads. The Ply-wood is cut around the studs. I want to seal the floor from mice, the rest will most likely be easy.
My question is, what should I use to seal around the studs, I was thinking silicone. Can mice eat through silicone? Or what is a better stuff to use?
Thanks for the help.
