OBD II port where is it?
55K views 10 replies 9 participants last post by  rabidranger
#1 ·
i'm trying to read the codes on my 97 ford 250 but i cann't find the diagnostic port to plug my code reader into i looked under the dash (where it is in my dodge) and in the engine bay but its not there. Is it behind something?
thanks for the help
jonathan
#4 ·
Is this a light duty F250(F150 body, 7 lug wheels?) Or a Heavy duty(92-96 F150 body style, over 8600lb GVWR, 5.8, 7.5 or 7.3L engine) If it's the second, it's entirely possible that it is OBD-1
#7 · (Edited)
My 1997 F250 HD with a 460 is OBD-1 and the connector is located on the driverside fenderwall in the engine compartment right next to the cruise contol module. It is trapeziodal in shape and usually has a cover to protect the terminals. You can jumper 2 of the terminals and count the check engine light blinks when you do a key on engine off check.
Look here:
http://fordfuelinjection.com/?p=13
#9 ·
Look here:
Is your truck mass air, or speed density?
#10 ·
It was a federal mandate that if an automotive manufacturer wanted to sell a vehicle in the United States starting with the 1996 model year, then it had to be OBD-II. All vehicles sold in the United States starting with the 1996 model year are OBD-II. Ford did use a diagnostic connector in the engine compartment, but that is for doing tests with the Ford scanners or the top end scanners the jobbers sell (Snap-On, Mac, Matco). You can read the codes with the inexpensive scanners you can purchase from the parts stores, but that’s all, read only. For the 96 (97 HD) body Ford Trucks, the Assembly Line Diagnostic Link (OBD-II) connector is somewhat hidden under the dash just to the left of center.
