oil cooler lines on 8.1L
1 reading
17K views 8 replies 5 participants last post by  odin544
#1 ·
What have you guys done about the factory oil cooler lines on your 8.1L or similar Chevy motors? It has a plastic quick disconnest right now with hard lines. I cant really afford braided lines. Any suggestions? anyone know what size the fitting is?
#2 ·
personally I did away with the cooler. Used the LS1 block off which provided a place to drill and tap for my autometer sender. I am just going to run a good syn oil. I would bet alot of others have done away with it as well. I dont see why hard fuel line would work, but it would be eaiser to run hose, I guess FI rubber hose would work, but dont know for sure.
#4 ·
Perfect timing Odin. I was just test fitting the headers on my 8.1 and I was wondering the same thing. WTF do I do with these oil cooler lines? LOL Hury up and figure it out so I don't need to worry about it :flipoff2:
I think I'm going to dig up a factory oil cooler and run it. I don't have a lot of space for a big rad so a little extra cooling won't hurt.
#8 ·
The fittings on the block are NPT fittings, so just get some NPT to AN fittings from summit. You should not just plug them per chevy. I talked to a few people at chevy about it and they were not sure if it would block all oil flow or not, but they said at a minimum you needed to connect them together, and recomended running a cooler of some kind.
I used the NPT to AN fittings, and bought cooler with 2 inlets and 2 outlets, one for my trany and one for the oil... No problems so far.
#9 ·
yeah I figured out what they were after I posted. I'm a little slow sometimes lol. They are 1/2" NPT.
I figured I would end up running AN fitting and braided hose or something. Im just trying to find a cheaper alternative for now. I talked to a local hydraulic shop about making some lines for me. There concern was how how the engine oil got. They said the hose they have will only handle 180*.
