Painting an axle???
16K views 35 replies 24 participants last post by  Beat95YJ
#1 ·
Can anyone recommend an easy-to-use paint that can be used to make an axle-housing look decent??? POR-15 comes to mind, but are there any other sugjestions???
#3 ·
Yea-rattle can black. Forget the POR 15, process takes too long and must be done perfectly to have the proper end results. Just go use some good old rattle cans.
Maybe you should post a question like this in the newbie section, instead of here, not many worry about how their axles look!
#4 ·
Maybe you should post a question like this in the newbie section, instead of here, not many worry about how their axles look! [/B][/QUOTE]
That may be, but I'm investing thousands on the project, including completely rebuilding the axles. Why not take some time and paint them?
#6 ·
Hammerite IS cool, but if you ever paint over it without completely removing the old paint, it will wrinkle the new paint.
I did my bumper with it once, and decided to go gloss black to match the rear powdercoat. I sanded it down, leaving some paint in the low spots. Within a few days, the new paint wrinkled in those areas.
You can also get Hammerite in quart and gallon cans, thin it, and use a spray gun.
I love the stuff.
M.
#7 ·
That may be, but I'm investing thousands on the project, including completely rebuilding the axles. Why not take some time and paint them? [/B][/QUOTE]
While your at it get a chrome diff cover for it aswell:flipoff2:
#8 ·
I used rusteloum gloss black. Cleaned the axle really well with first super clean, then simple green, getting as much of the crud off of it as I could. Washed it over and over with the pressure washer, let it sit outside for a day or 2 to completely dry, then laid down about 6-7 thin coats. I let it dry until it was hard before I moved it (I think it is 48 or 72 hours), and it turned out great.
#12 ·
Don't get me wrong, just figured this would be more suited for the newbie section.
I know what your saying when it comes to making it look decent while it's all ripped apart, do it right the first time. POR is a pain to work with, I've done the frame of my FJ40 in it and it took about 100 hours between prep and paint, that's having it professionally sandblasted. POR 15 is expensive when all is said and done, go for the stuff that's easy to work with and can be touched up without high cost, Krylon, rustoleum or Hammerite are all decent and easy enough to touch up.
#13 ·
Funny you should start this thread...I just got in from painting my front axle housing...HAMMERITE BLACK.
Honestly, it's the best thing going, it'll smooth out just about any knicks, it cleans up well once it's dry (duh), and you can touch it up forever.
I think of it as 'Poor Man's Powder Coating'.
'Course if you are spending thousands like you say (who hasn't on their own truck though...), you ought to get them powdercoated.
:flipoff2:
#18 ·
If you are really going to wheel it, I'd have to agree with tanzuki...get the cheapest paint you can find. I don't care what you put on there, first time you smack a rock or whatever, the paint is probably going to came off.
The Walmart brand stuff looks nice and shines for a decent while. If you feel that it looks bad, buy another can and there ya go.
I made this mistake with my bumper. I spent $40-50 on Rustoleum paint, multiple coats, lots of work. Yeah, it looked damn good. But then the wife backed her car into it. SO, there went all the hard work and money. I cleaned the edges up as best as possible and shot it with Wallyworld paint. Other than the lines from the original layer being so thick, you can't tell the difference.
So, IMHO, save your money and time, prime and paint them with the less than a buck a can stuff...really.
#26 ·
Normally semi-gloss rustoleum or krylon. As it is I am surprised I even have metal left on the bottom of my diff. lose the paint to a rock, get home, hose off the axle, let dry, shoot with one of the many cans I have in the garage and presto, all better! it is the only way to go with and axle...
