Removable Doors for XJ
1 reading
12K views 10 replies 8 participants last post by  AthlonAJ
#1 ·
I'm surprised I can't find this easily, but I want to adapt my current XJ doors to be removeable.
Right now the hinge is broken, so the door is off...but instead of just fixing it, I'd like to have it be removeable.
The idea is that later I can make some half doors, or something similar.
Does anyone know of anyone who has done this? I'm sure someone has.
thanks
#2 ·
You can drive the roll pins out or drill them if you really like to torture yourself. Then cut off the bottom ears and replace the pin with a bolt or solid stock. The doors will lift right off. OR you could do something like what I have started, put TJ hinges on. That is A LOT of work though just to have removeable doors.
#3 ·
Hmm.... TJ hinges
We just got done completly swapping out a 95 to this 87 (the 95 was rolled) and 4-6 of us spent about 50 hours each on it, so we are ok for work. =)
but the TJ hinges are interesting to me. Did you already do that, or are you just looking into it?
thanks for the advice
#8 ·
Cutting off the lower ears is a pretty easy approach. We did it to an XJ of a friend of mine, and it worked out really well. You should see the looks he gets driving around in a mud covered XJ with clean doors. It's pretty much trail only (other than the highway to and from), so he didn't even bother putting a pin on the bottom. Its really quick and easy to remove the doors, just pull a couple of plugs, and lift the doors up and out. As said before - It makes it really easy to line everything up when reinstalling.
JH
#9 ·
Re: Hmm.... TJ hinges
I started on it but have been off work since Jan. from a botched surgery. :( All I have done right now is some of the support structure inside the door. Since the door is curved though it would probably bind the hinges and make them "unremoveable". The plan is to build them out enough top and bottom to make them both perfectly vertical, recess a little here, bump out a little there... Basically if you think of it in your head, you build the structure so that it's from the front of the door where the old mounts are directly to the hinges, the door itself is just a skin.
On the fender side I'm scrapping the stock fenders anyways. Building tube fenders from scratch so getting the structural strength I need won't be a problem there.
#10 ·
JH
I've done this too, NO WAY - would I fawk with fabbing up TJ hinges:rolleyes: K.I.S.S. is always best:p
