For all of you out there that have swapped in a SBC, I used TPI, what have you done about the speedo and the tach. How did you hook them up? How did you wire them? ETC, ETC!
Thanks
Thanks
Sometimes the solution to a problem like this is NOT to just chuck out the old OEM partyou have to change the tach to a v8 tach
If the documents that came with my gauges are to be believed, GM trucks use a 16-pulse-per-revolution system...Charly said:Actually, the earlier injected YJs (I think it's the 4 cyl TBIs) use the mechanical speedo and a VSS (basically an inline VSS), but I'm not sure if it's the same pulse generation as a GM computer needs (I know some VSS's are 2 pulse, some 4). I believe it will thread onto a 300.
