Small block chevy serpentine belt setup, $80 NJ
1 reading
4.9K views 1 reply 1 participant last post by  uw
#1 · (Edited)
This was pulled from a 1990 C1500 5.0L SBC. With a standard alternator it will use the standard 1990 C1500 5.0L belt.
Here is what is included:
-Power steering + alternator bracket: 10118701
-Power steering pulley: 14102096 NL
-Power steering pump (not sure if good, probably and I believe I have a life time warranty receipt for it from pepboys)
-Water pump pulley: 14102093 NH
-Crank accessory pulley: 14102091 ND
-Air conditioner compressor + smog pump bracket: 10129515 (NMP 5)
-Belt tensioner and pulley: 14102108* (note this is just the pulley PN, not the whole assembly)
-Mounting bolts for the PS+alt bracket
-Mounting bolts for the A/C+smog bracket
-Air conditioner compressor: It does not work however if you want it it's yours as an idler/core. I don't have bolts for it though.
-Belt in good condition Also the belt to use with this setup is 6 rib x 94”, rock auto has Goodyear part number 4060940 for $6.12.
Looking for $80 for everything in the picture
I can clean and media blast everything to a nice smooth finish, making it ready for paint or anodize. That will cost an extra $50, for my labor and consumables. These brackets are high grade aluminum and will anodize nicely (I have done this before).
If you're doing a conversion, to complete this kit I THINK you will need 1 or 2 things. I will help you along the way too for no charge.
1. serpentine alternator (or just the 60mm pulley) along with some odds and ends hardware from your old setup.
2. If you'd like to buy pass the A/C check out part number 10118713. They are about $25 on ebay with free shipping.
You have insufficient privileges to reply here.
