What kind of steel do I need to machine a couple of custom axles?
4340?
4340?
Thanks for your assistance!camo said:i don't mean to sound like a dick but there is alot more to building axles than what metal to use. if you have not even done the research to understand the sciennce behind the proper metals to use for your application then i can only question that you do not have enuff understandig to properly machine an axle. their is alot more to the design of a proper axle than sticking some splines on it.
start reading and learning.
Yep, I was trying to start learning.camo said:i don't mean to sound like a dick but there is alot more to building axles than what metal to use. if you have not even done the research to understand the sciennce behind the proper metals to use for your application then i can only question that you do not have enuff understandig to properly machine an axle. their is alot more to the design of a proper axle than sticking some splines on it.
I'd have to agree with you 100% but I have seen very few properly designed axles here, about the only ones made right are your's that Sandy made, even Jack's shafts leave much to be desired.camo said:i don't mean to sound like a dick but there is alot more to building axles than what metal to use. if you have not even done the research to understand the sciennce behind the proper metals to use for your application then i can only question that you do not have enuff understandig to properly machine an axle. their is alot more to the design of a proper axle than sticking some splines on it.
If you are going to make a set of custom axle, 4340, heat treated to RC 46-50 generally works well, you can also use 300M, but most of the time it is unneccessary.
Yes, 4140 is also a good material and many axles are made of it, the main difference is that 4340 thru hardens better and you can take it to a higher hardness and therefore higher stress levels, when you are mass producing axles, you can save some money by using 4140 as long as you have designed for it, but if you are just making one set, the material costs are only a small factor in the cost, so you may as well the better material.scO44 said:Isn't 4140 pretty decent axle material as well? What are the difs between 4140 and 4340?
Scott
I use 4340 all the time but 42 to 44 max., 46 to 50 is to high for me . steve differential eng. inc.
And what aftermarket manufacturer rolls splines?rabidranger said:The splines are also forged into the axle for greater strength than cut splines. Check out where I used to work, www.aam.com.
Realistically I don't see how it would significantly matter between rolling or cutting as long as time and care is taken to improve the machined surfaces. Yes, I am highly aware of the differences and the cold working of the metal, stress risers and all that other good stuff.Oxjockey said:
How much stronger, percentage wise, are rolled vs cut splines?
Production axles are case-hardened by induction hardening, it can have advantages, but the main reason manufacturers do it is cost, it is fast and cheap and allows them to use medium carbon mild steel which is very cheap. Just about every alloy race axle is thru hardened, a case-hardened carbon steel axle doesnt even compare in strength, they don't shatter either.rabidranger said:Axles are also case-hardened, not thru hardened. This allows the axle shaft to have strength, but also have some twist under severe load. A thru hardened axle would shatter under heavy load. The case depth is also dependant on the overall axle diameter. The splines are also forged into the axle for greater strength than cut splines. Check out where I used to work, www.aam.com.
Case hardening is a term used for parts, not axles. Gears are case hardened, only .060 to .100 deep. The strongest racing axles are thur hardened, take it up strange they have be doing this longer than anyone. Heat induction is good for 35% depth of the shaft. steve differential eng. inc.
I would suggest using an exotic such as Lignam Vitai, it machines quite well and is self lubricating.fatkid said:Ever thought of using wood for axles? That would be easy to make...
