Been lurking here for a couple years, finally decided to post my build on here. I have had the pickup since 2010, and used it for a daily driver while I was in college, and did some mild mods to it. I have never lived at a house with a shop or garage so the process has been slow.
I ran it stock height with 33x12.50R15 Maxxis Bighorns, they rubbed pretty good haha
Did a spool locker in the rear, and welded the front differential. In this setup I could tag along with built rigs in the snow, and was a pretty cheap way to wheel.
Once I graduated college I was able to afford doing the mods I wanted. In my years lurking I decided I wanted to have 36'' Iroks with 5:29's and a single 4:7 case, and eventually move onto a dual transer case setup.
SAS came out ok for my first time. I should have moved the front shackle mounts forward. I was pretty dissappointed when my front shackle angle came out so bad. I don't think the springs are completely broken in yet though.
Progress pics
https://imgur.com/a/rpKJV
Eaton Beadlocks
https://imgur.com/a/TZkOc
Recent progress
https://imgur.com/a/jpMfQ
More progress
https://imgur.com/a/ny3Dl
Future plans: build a mini flatbed that will hold my spare, a tool box, a cooler and maybe a tote for camping gear. Longfield axles, 5th knuckle stud upgrade, knuckle trusses, finish bumpstops and build bumpers and rock sliders. Pull the 3.0 out and do a 3.4 swap. ISO blown 3.4 if you know anyone!
Current specs:
4'' Trail gear HD springs front 4'' rear
TG SAS kit
Yukon 5:29 gears from Randy's Ring and pinion
Spartan locker front, spool locker rear.
36'' Iroks with Eaton bead locks.
Swapped a 4:7 gear transfer case w/adapter plate for 3.0 tranny.
Trail gear 10'' slip front driveline. Stock rear driveline w/spicer u-joint.
Electric fan on the 3.0, and custom exhaust by D&M in Ellensburg.
Trunnion bearing eliminator kit
Progress pics
Eaton Beadlocks
Recent progress
More progress
Current specs:
TG SAS kit
