I'm having some issues with my TF999. I'm running a stockish 360, 999, and stock D300. The last time out, I had an odd problem with the rig. Forward gears were just fine. BUT, when I shifted it to reverse, the tranny bogged down the motor and damned near stalled it. It had zero power and didn't want to move, but would with enough gas.
I did mash the deep tranny pan on an earlier trail ride, lost about 2 quarts, then limped it out under tow, then replaced it with a regular pan. It had fluid, good red color. I'm lost. Fluid level is fine...checked it warm, while in neutral.
If I need another tranny, I'm thinking of having this one rebuilt like the link below. Deeper first gear, using a reverse manual VB with compression braking. I don't have compression braking in 1st gear as it is with the Cheetah MVB.
Check out post #12:
http://www.pirate4x4.com/forum/showthread.php?t=433609&highlight=999+reverse
Check out post #12:
