The Minion Scout 800 - LS swap with NV4500 inside
11K views 9 replies 4 participants last post by  Rjcruz47
#1 ·
While I may not agree with it, the wife has nicknamed her the Minion. The Minion is a '67 800 I picked up about 4-5 years ago and did the initial build then. Have put many miles on her and everything is working pretty well. In the mean time i built a LQ9 from spare parts and found a NV4500 mated with a D300. I have been sitting on these parts for some time and just recently started to do the swap. Along with the swap she will finally get power brakes and completely rewired and re-plumbed.
First build included the following: Scout II Dana 44 front and rear, lockers with 4.56 gears, Chevy flat top knuckles with high steer arm, Scout II power steering box tapped and PSC hydro assist ram. Tires and wheels are from a trade deal I made and suspension is made to fit with stock Waggy and Scout II springs. Cage, seats, sliders, rear bumper, rear Warn 8000# winch all help add to her 4580lbs starting weight. Waiting to see how much weight the iron block LQ saves vs the heavy 266 V8.
3108388
Pulled the factory 266 V8, T-18 four speed, and D20 case. These will be rebuilt and used in a '66 800 half cab I picked up two years back.
3108389
3108390
New clutch installed and mated the 6.0l to the NV4500/D300 combo.
3108391
Removed factory frame mounts and saved to use when the 266 goes in the '66. Lined up everything and made an engine cross member then burned in the mounts. Also in these pictures you can see the mock up of Hydroboost, and factory GM clutch master behind the battery.
3108392
3108393
Made sure to leave room for links and panhard for the 3-link to come.
3108394
3108395
Now she waits for the F-body aluminum radiator and cooling fans to be installed. Before that I need to install the AC compressor to be used for onboard air.
Discussion starter · #2 ·
Here is the '66 that will be getting the 266 after it is freshened up. Have a set of waggy D44s to go in along with that motor swap. Picked up a bench seat, and a half cab top for it locally, still need a set of 800 doors for her.
3108548
Discussion starter · #5 ·
Quick update:
Finished up the install and she is running and driving. Need to get a new battery for my tuning laptop to clean up the EFI tune. Intake tube is temporary and coolant res, working on an air box for the passenger fender area.
3111786
3111787
Discussion starter · #9 ·
Just to update this thread. Have been really busy with work and the second scout build so not much changes. Auto meter gauges added to stock panel until I trim for the 6 gauge dash. Little cleaning up on the tune, and many miles on her now.
3117998
3117999
