Howdy everyone -
I've got a 16' bumper pull with brakes on one axle. The brakes were working, but not well enough to lock them up on an empty trailer, so I figured it was time to do some work on them. I bought new backing plates loaded with shoes and magnets and installed them this weekend. Got it all put together and the brakes are working just as poorly as before. They technically work, but even with the gain set at max, I can't get the wheels to lock up (even on gravel) at 10-20mph.
What else should I be looking at? I'm going to check the voltage at the wheels this evening to make sure it's getting full power. If it isn't, I'll start looking for bad grounds (the ground wire runs all the way back to the plug for the brakes, so I'm not expecting a bad ground). If the magnets are getting full power, what else should I check? I reused the same drums that I had before... would new drums make that much of a difference?
FYI, I'm using the factory trailer brake control in my 2006 F250. My dad has the same truck and the brakes work the same behind either of our trucks, so I'm ruling out the TBC.
Let me know what ya'll think.
Thanks,
- Steve
Thanks,
- Steve
