I have just swapped in an 05 5.3 with a turbo 350 into my 86 4runner. The wiring harness is a stock harness that has been modified by me:laughing:
Specs...
2005 suburban 1500 4wd 5.3
Advance adapters headers (if it matters)
Evap sol. is removed
all trans controls are removed
turbo 350
reprogrammed ECU (by pacific fabrication)
Engine light is hooked up
Tach is not hooked up (trying to keep the stock toyota instrument cluster)
now for the problems...
The truck isnt getting any spark. Nor is the ECU talking to the scan tool. I have checked the power wires and grounds and all of them seem to check out. I am getting full time 12v and ignition supplied 12v. All of the grounds have connectivity to the negative terminal of the battery. I am also getting 12v to the coils but no ground or spark trigger. I have not checked to see if the crank sensor is good (any info on how to do that?) but the wires going to it are intact. Getting a new harness is a possibility. Trying to get this thing goin for some new years snow wheelin! Got any ideas??? Thanks in advance
Specs...
turbo 350
