What are the benefits of each? Which can handle for hp of a built LS1. Around 450HP to start but more mods at a later date.
Make sure you have the correct flexplate for the engine. The bolt pattern for the converter will bolt to any 700 / 4L60 converter for V8's. 3 piece 4L60/65E trannys use different converter bolt pattern( bell housing unbolts)
the V8 style 4L60 and 700 are the same. the converters are the same , the flex plates bolt pattern for converter are the same. All bolts are still metric. 700 trannys have always been fully metric.
there are minor differences in 700r4 & 4L60's, but they all interchange parts. Later design parts are better. Some valve bodies & separator plates do not inter change from late to early design
700r4 name was changed to 4L60 when GM updated several areas of the trannys. Parts are basically the same.
GM updated listing names on the trannys ; 4L80E , 4T65E , etc.
4L60E & 65E are different in several areas from the non "E" units.
The 3 piece 4L60E tranny case design is different again. Different pump stator , converter design is different.
Early 700 pumps and stator parts must be watched for mis-match. You will have little or no pressure with mismatched parts of early pump / stator designs.
I have done some research even though you probably will not believe it:flipoff2: It helps with my father specializing in tranny's
KOH/Ultra 4 carWhats it going into, what are the plans for it as well?
