YJ Rear Driveshaft
4.2K views 11 replies 4 participants last post by  blugreenformula
#1 · (Edited)
I have a YJ with SOA on stock YJ springs and stock wheelbase running 39.5s. What are you guys doing for rear driveshafts? I made one with a cv but it is already almost maxed out just setting there. Im not really looking to stretch it but could if its a MUST. Any pics of your rear driveshaft at the t-case? Also im running a c6 and 205.
EDIT: Ooops. Meant to put in the Jeep non hardcore
#6 ·
Tom woods and High Angle driveline were the first two I could think of.
http://www.4xshaft.com/index.html
http://www.highangledriveline.com/
Neither of them list prices on their site so you will have to call for a quote. It may be expensive, but it will most likley be the cheapest way to go besides lowering your ride height.
You can also run your springs backwards to get you about 1.25 more driveshaft since the centering pin on a yj leaf pack is not centered.
#8 ·
Actually the center pin is centered.
Hmm, my stock 91 YJ springs were not and neither are the RE 4.5 springs I have now.
But anyway, That offset u-joint will not work in your double cardan unit, but I do not see why you could not use it in place of your double cardan set up. I have heard alot of people say that they do not last, but I have no experience to support this. In reality, a double cardan joint is not made to provied more angle, but less vibration. I would think that you will get quite a bit of it with a single cardan like that though.
#10 ·
The part of the DC that serves as the mounting point for the driveshaft (forgive me, I can not remember what it is called) has to engage the centering ball within the coupling yoke and also serve as the seat for the u-joint that is on your rear output. With a offset u joint, all four caps will not be able to be in their proper seats and allow the centering ball to set into place.
