We bought a new 5er and my truck (99 Superduty 3rd gen Cummins 325/610+, ZF6) is a bit overgeared pulling it with 275/65R20s. (605 revs per mile)
At 60 MPH, my engine is turning 1624 RPM in OD. It pulls it but there isn't much left under the pedal. The next gear down (Direct) is 2250 RPM, which revs a bit faster than what I need.
I'd like an auxiliary overdrive so that I could pull in direct on the ZF6 and OD on the auxiliary.
I thought about an rto6610 and discounted it for a few reasons. 1) it would shift like a big truck transmission. I like they way my ZF shifts. 2) I would have to manufacture a new bellhousing / bellhousing adapter. 3) They are a big, heavy transmission. One generally has to cut the floorboards to make them fit 4) They are noisier than the ZF 5) They are not easy to find 6) The split between gears is still 25% plus, except OD which is 20%. 7) OD is 0.80 which is slower than the ZF 6 which is 0.72, so I would probably have to change the diff gearing as well.
I've looked at the Gear Vendor ODs a couple times. I discounted them because I've seen them break, they aren't selling anymore and they won't work with an exhaust brake.
So... I started looking at other transmissions and came across a kit to convert a rt9509 to a rto9513.
See
http://www.roadranger.com/Roadranger/productssolutions/transmissions/rtoc-16909a/index.htm
and
http://www.roadranger.com/ecm/idcplg?IdcService=GET_FILE&dID=10852
The 9513 splitter has 2 gears: direct (1:1) and OD (0.87:1)
This would give my truck the following engine speed combinations at 60 MPH
ZF/Splitter
OD/OD 1412 <-- 1650@ 70, 1766@ 75
OD/Direct 1624 <-- what I have now
Direct/OD 1961 <-- perfect for pulling
Direct/Direct 2254 <-- long hill gear
3rd/OD 2568
3rd/Direct 2952
My thinking is to get the splitter box from a salvaged 9513 and build a plate to replace the transmission that it normally bolts to. I would then mount it on my truck where the carrier bearing currently sits.
Shifting it would be no problem because I already have a compressor on my truck for the air ride suspension.
The 9513 allows one to split all the gears in the High range. The lowest gear in the high range (5th) has a ratio of 2.481. From this I gather than the splitter box is good for 950 x 2.48 = 2356 ftlbs. My Cummins makes about 650 ftlbs. This means I shouldn't use the splitter in LO on the ZF6, but I could use it in 1st.
Comments ?
See
and
ZF/Splitter
3rd/OD 2568
3rd/Direct 2952
Comments ?
