Cj2a scout axles
1 reading
5K views 9 replies 8 participants last post by  Dirt-Fab
#1 ·
Hi I'm new to this stuff my name is Dillon. I have a 48 CJ2A that I cracked the frame on not to long ago. I've got a new frame and I figured when I was doing the swap that I would make a few other modifications. What I'm going to do is danna 44s from a scout. I'm going to keep them the same width I think, and just move the shackles instead of shortening the axle. What my question is what do I have to do to adjust the camber and what do people do about steering and tie rods.
#4 ·
Scout II axles are not necessarily a bad choice to start with, but there are some things to consider. Knuckles are unique along with the 8-bolt spindles. Not a big deal, but parts are less common. The biggest issue with them is that they have very little to no caster built into them. Cutting the weld and rotating the C's would be a good idea and would provide better handling.
#9 · (Edited)
I would use the dodge stuff to, its stronger. I hate my scout hubs but their staying till they blow :nuke:
#10 ·
The reason I am using an old Warn internal style hub conversion- I hate the CJ 5-bolt locking hubs. Seen too many failures.
That being said, the advantage to the CJ stuff vs. the Dodge/Chevy/Wagoneer spindles and hubs is the distance from balljoint to wheel mount surface(WMS). If you want narrow axles/WMS to WMS then the CJ stuff will buy yourself some more axle tube to play with. Axle tube real estate can be important for spring mounts or link mounts if you ever decide to link it up.
The advantage to the fullsize stuff Dodge/Chevy/Wagoneer parts is they are much more available, stronger parts, bigger bearings, & internal style hubs etc.
