21 - 40 of 214 Posts
I sold my Torchmate because I don’t use it enough but for the cost this one might be cool to have. Looking forward to the review when GTx gets his. :smokin:
Shipping delayed to July due to a vendor delay. Looks like the majority of the hard parts are being made right here in the US. I know the electronics are overseas, which is fine, but it's nice to see some of it being made here.
Might be worth a trip to the left side if you wouldn't mind show and tell. I'm thinking for just the minimal tabs and brackets I make now on my mill this would be the ticket. Waiting and watching for updates.
Yeah give me a shout if you're ever on this side.
They delayed shipments to mid July but they claim to be on track now for all deliveries. Stoked to have mine, I have a few projects waiting for this little guy.
First production table off the line with upgrades. Taken from Book of Faces and the Langmiur Blog:
https://www.facebook.com/pg/LangmuirSystems/photos/?tab=album&album_id=1821041571535586
Langmuir Systems
Langmiur Blog Page said:
Hi Everyone,
We are excited to send out another quick update with pictures of the first official production machine coming off our assembly line. This machine is completely manufactured from final production tooling and processes at our vendors and in our shop in California. This machine has been processed through our assembly line tooling and fixtures which are used to ensure that all your CrossFire machines are tuned and QC tested before being packaged up and sent out.
We have several unboxing, assembly, CAD/CAM, and cutting video tutorials coming your way soon so stay tuned for these in the coming weeks! If you haven’t done so already, please subscribe to our Langmuir Systems YouTube Channel to stay notified when new videos are uploaded.
Here are some pictures of the production machine. You’ll notice some upgrades from our original:
  • High Quality Textured Powder Coated Frame - A new powder coating process was used for a higher quality, more durable finish on the frame tubes. This is also a shade or two darker than our original machine to hide some dirt and grime of the plasma cutting process.
  • Electronically Isolated Torch Firing Input Cable - Easier and safer way to connect your torch firing cable to the CrossFire electronics enclosure. This also makes it quick and easy to unplug your plasma cutter from the CrossFire to make manual cuts off of the machine.
  • Woodruff Key Bearing Adjustment System - Easily adjust the CrossFire bearing blocks with an improved Woodruff Key alignment system. Tighten set screws in the CrossFire’s milled bearing blocks to ensure a precise fit around the gantry rail tube. These bearing blocks will arrive at your door already adjusted here in our factory!
  • Upgraded Gantry Rail Tube - US made steel tube with superior straightness and flatness that is individually milled, fitted, and aligned at the
  • Langmuir Systems facility. After zinc plating to prevent rust, this tube will work harden along the bearing track surfaces giving you incredibly smooth and precise movement.
  • Aluminum Water Tray - Our new aluminum water tray boasts many improvements over the original’s steel tray including rust resistance, weight savings, and ease of drainage with removable slat holders and brass drain fitting. Swapping between the water table and the stock slat holder configuration takes minutes!
Before CrossFire systems and plasma machines arrive at your door, we will begin stocking consumables for purchase in our online store (Razorweld nozzles, electrodes, swirl rings, retaining caps, and replacement CrossFire slat packs) as well as add-ons for individual sale.
Our estimated ship dates for Batch 1 remain in the second half of July and the Batch 2 ship dates remain in September. We are happy to report that Batch 2 production is already underway at our vendors and moving forward without a hitch.
For customers that purchased Laptop Computers, Razorweld Plasma Cutters, and Software licenses we will begin to start shipping out these items in the next coming weeks so keep an eye out for tracking information via email!
We can’t wait to see what you will make with the first set of CrossFire machines and we want to thank our pre-order customers for supporting us along the way!
I still don't like the single sided gantry, and I still think a Z-axis is really important, in fact I know it is. Pierce height vs, run height etc. No THC..
BUT:
Those bearing blocks look slick as hell, I really really like them, a bit too much engineering and machining for a home gamer..
AND:
I'm digging the way the motors are setup with lead screws, its a really compact slick looking setup.
I think if they go into production and are successful, they should take the design and kick it up with a double sided gantry, and a z-axis for their Mk.2 version. It'd be a really neat looking and functioning machine.
nice thing about the single sided gantry is letting material hang off over the side, you don't need to pre-cut sheets as much.
BUT:
AND:
I definitely agree on all those points but that's also why the other tables are more expensive. I think they are breaking into the budget garage builder market more than the entry pro tables like ArcLight Dynamics and what used to be Torchmate. $10k-$15k was the norm for a table and that's ridiculous for a guy that cuts once a month or just wants a simple 2x2. They have said they'll offer expansion options and a double roller gantry in the future. As for the Z axis, the Mach3 will already do that, just buy an aluminum corkscrew Z axis and motor and keep it light or install said double roller gantry.
Yeah I really like this part, I use full sheets that I cut down with the handle torch. Then load the machine and go.
Mines 3.5 x about 2.5 ft.. just the other day I was annoyed that my material couldn't fit how I wanted it to.
I need to put a spacer in, because I'm literally 1/4" from getting the bolts to clear if I run the material under the rails.
But I did think exactly what you're saying there when I was looking at the pictures.
Vibration on that single sided gantry is gonna suck. sawtooth edges and no THC, no Touch and go... I see a lot of nope in that thing, the bearings riding on square tube... Blah... of course I have real tables to deal with... I guess if you NEEDED to be able to cut $2 plates gussets and such for personal use it would be OK but for what I do for a living just nope....
Interesting, I posted on this thread and my post vanished... guess I can't say anything about this thing... the single sided gantry will vibrate and cause crappy edge quality, no THC, no Touch and go, Rollers on square tube... crap. If you need a thousand dollar toy to make $2 tabs, plates and Gussets... go for it. but it is not a serious machine. I have two serious machines in the shop...
i've had the same thing happen a few times lately, just have some faith that the post went through!
hell, i lost a whole thread i was reading and then it suddenly re-appeared :rasta: :confused:
for $1k it isn't intended to compete with a serious machine, but it would be reasonably capable to make a great many parts, moreso than just tabs. cut a little large and finish with a sander and nobody would know the difference :flipoff2:
it isn't a production machine and it isn't for folks who highly value things like edge cut quality and saving second or minutes; those folks will gladly spend 10 or 100x the price.
on their site they sell the laptop for 349$
specs of the Acer laptop
Intel Celeron N3450 Quad-Core Processor (Up to 2.2GHz)
14" Full HD (1920 x 1080) Widescreen LED-backlit Display
Intel HD Graphics 500
4GB SDRAM Onboard Memory
32GB Internal Storage
802.11ac WiFi (Dual-Band 2.4GHz and 5GHz)
1 - USB 3.0 Port & 2 - USB 2.0 ports
1 - HDMI port
Windows 10 Home
2-cell Li-Ion (4810 mAh) Battery, Up to 9 Hours Battery Life
same spec laptop on amazon is 169$
any reason not to get one from amazon??
14" Full HD 1920 x 1080 Widescreen Display. 300 Kilopixel (Front camera)
4GB Onboard Memory, 32GB Internal Storage
Windows 10 Home
also thinking about getting harbor freight compressed air dryer
but thats another 450$ with tax and shipping:(
