Even leaf spring suspensions will differ from person to person and rig to rig, for a good example, I daily drove my jeep for a few years with rear YJ springs front and rear and SOA. I had loosened the clamps so they were striaight up and down, I did a shackle reversal in the front, home made with a long rear shackle, all to keep my hieght down and still allow for a good spring travel.
Here is a pic of the front hanger, it's a piece of 3" square tube cut up...
The rear shackle... I used a stock front hanger welded to the top of the frame and made the shackles out of 3/8" flat stock...
In that last picture you can see the spring clamps are still in stock location, i have not heated them up yet with a torch and bent them straight...
Here you can see the clamps straightened out... I also rebuilt the leaf packs when I did this with the torch... I think if you are using any used springs, the best thing you can do is rebuild them... take them apart, clean them, paint them... and if they are supposed to have those plastic spring pads on the ends, put good ones on and then grease the ends (plastic or not), this will help the leaf's move and keep the friction to a minimum... I also cut the ends off of another main leaf and add that long flat leaf to all the packs, to help keep there shape... and this worked until I went bigger..
Now I did this all prior to building the rig for daily driving and wheeling... I was on 3/4 ton axles and 35" tires... it worked wonderfully... much flex... soft ride on the street... I loved it... the springs stayed straight and all was good.
But then I stepped up to one tons and these 38's SX's and it was just too much flex and way to soft... I had major axle wrap and the front axle actually walked out from under my rig a few times while climbing... so...
With that said, I heated up those clamps and bent them back around the springs... I also hosed clamped the very front spring packs together and duct taped them up... also welded a chain around them, all to keep them together and from walking out... it's many times better, but still unloads on steep climbs and so far has not walked out on me, but I am sure they are trying too... it still flexes enough for anything I have done at the Hammers...
In this picture you can see the passenger spring has all my clamps on it while the driver side doesn't... and you can see how the spring is sliding off to the side... another reason to clamp them in the front...
The only way to really get YOUR leaf's doing what you want, is to use your rig, and when folks take pictures and video of you, analyze it... watch others and the way their rigs are handling... then modify yours to try and get to where you want to be...
No one on here can tell you how to set up your leaves. We can tell you what we did and why... and then make your decision for yours from that, but don't think you can just put them in and be done with them... well you can and they will work to a degree... but I think most of us want our rigs to be the best or we wouldn't be modifying them to death... so be patient and you might have to take them out a few times... or at least make some changes here and there.
