I am searching but having a hard time finding the best approach here. The Wrangler TJ's have a PITA setup and ring to replace a fuel pump on the trail, and the design is crappy to start with, plus the internal support plastic piece is known to brake easily.
I want to make things simple and have an external pump, what could be a 15 minute fix as opposed to an hour fix.
What have you gusy been using and what worked? I believe the most used setup is the Ford and ES2000? What has to be done to teh pump, rail, pickup, etc?
This will be on a TJ with a 4.0L engine.
Thanks!
Thanks!
