Hey y'all,
I realize my Jeep isn't particularly "hardcore", but I wouldn't typically consider backhalfing a Jeep frame "non-hardcore" so if a mod feels the need to move it to a different section, go for it. I won't be butt hurt.
So I've been wanting to do a 5"-6" rear stretch on my TJ for about 8 years and after a couple years of gathering the (rather pricey) parts I'd need, I finally decided to get going. The plan is to incorporate these items:
I was originally planning on doing what most people do, i.e. keep the factory frame and french in the shock towers. But it always looks like poop to me to have the rear axle not line up with the hump in the frame. So I began researching and I decided to backhalf my chassis. It came down to Artec or Undercover Fab and I decided on UCF. Unfortunately, I found next to NO information out there on someone documenting the process. Fortunately, Matt at UCF was always available to lend a hand with my questions.
Below is a recount of what happened and some of the issues we encountered....
First things first.....remove the gas tank, axle, suspension, driveshaft, and cut the frame. I cut the axle as close to the frame hump as I could get with the stock spring perch in the way. Turns out this is a bit more critical of a cut than one might imagine and the angle is pretty important here.
A couple things to note here. The first pic shows that the new frame will be quite a bit higher than the stock frame. So keep that in mind! I didn't realize that was going to be the case.
And this pic shows the angle the cut should've been on the frame. The angle should match the leading edge of the UCF framerails.
Now here's where things get weird. I plan to use a GenRight tank which uses a stock style mounting method. However, the new rear crossmember will be a lot higher than the stock one. But the tank can't go that high since it would go through the floor. I decided I wanted to keep the frame a little lower to make it possible to attach the GenRight tank and not have it look like an afterthought. This would prove to be challenging. If you wanted to run a fuel cell, this would be a much simpler install and you could run the frame as high as you'd like.
So now the orig. chassis rails are trimmed and the UCF rails mate up nicely to it.
But because of the cut, the framerails moved forward. The included rear bumper now has no way of sliding over the framerails. That's somewhat visible here if you look where the bumper/framerail meet.
- GenRight comp tank (stock capacity)
- GenRight aluminum corners (not comp cut)
- GenRight steel flares
- Poly Performance shock towers
- ORI 12" STX struts
